how can i tell if lag spikes are caused by mudfish or my net? is there a way to see what the normal traffic is like at the same time while running mudfish the same way wtfast does?
i have, you recommended me some default settings when i asked something similar before. im using the default settings.
You should set TCP to connect to Final Fantaxy XIV: A Realm Reborn.
That last picture occurs misunderstood for some users so I removed pre-configured radio buttons.
after updating and changing to TCP the spikes still happen but not as high so less likely to cause a disconnection. I think at this point the spikes are due to my net and not the program.
