how does passing game traffic only work? So that means no matter what, only the data the game uses will count towards the data plan? Also, if my game needs to patch a huge update (like 1G+), does that also go under game traffic?
At mudfish, it’s working based on the routing table of OS.
For most of cases it should be but there’s some edge cases when CDN is involved.
For this case my answer is yes or no depending on the game item.
To be safe from this update, I think you can use Subscription data plan or turn off mudfish when you update the patches.
이 게임 서버의 경우 이미 처리해 드린 것으로 보입니다.
확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
네 감사합니다~
그럼 요청 해결되신 것으로 판단하겠습니다. 혹시 다른 이슈 있으시다면 언제든지 말씀해 주세요.
