how i could know how many GB will be giving with the pries you offer ?
hello is there any problem in the servers at the time ?
No problem. I’d refunded it now. Please check and let me know if there’s anything I missed.
nothing i guess thank you mate ^^
what happen ? why all my GB disappear؟
not at all ^^"
hello guys i am facing that code 00330 error … so how could i fix it with out pick PTT plan ?
yeah that what i meant ^^
패킷 덤프 보내주셔서 감사합니다. 제가 보내주신 덤프를 기반으로 아이템 ‘Dying Light’ 을 만들어 보았는데, 한번 테스트 부탁드리겠습니다. 시도해 보시고 여전히 제대로 동작을 하지 않는다면 말씀해 주세요.
그리고 패킷 덤프를 보아 게임 서버가 유럽 독일 쪽에 있는 것으로 확인되는데, 혹시나 제가 잘못 처리하였다면 말씀해 주세요.
- Please check basic
functionality
Please try to
enable Full VPN
mode -
use
-O
option to change the Mudfish’s working method as refer
Firewall - Mudfish
Master
Server
consider to change MAC
Address -
consider reducing
MTU from
1450
- Is your Operating System Microsoft Windows XP? Have you entered routing table by yourself?
- Please check MUDEC_00003
Please try to turn off FastConnect mode or change your Connection
Protocol.
FastConnect
mode
will NOT useful in UDP. This feature is for TCP services.
- Please check if you have modified registry like Latency Fix / FastPing
or failed to install Mudfish
