hello, i have buy $4.99 subscribe. but, the issue is im playing on china network that have GFW (Great Firewall). can you help me step by step how to setup mudfish for albion online? im playing on EU Server. please help me
Thank you
Thank you
i want to optimize ping, running without mudfish i get around 250ms ping. after using mudifish, ping remain same. how to know which best node to use?
Thank you
I can’t help you with specific GFW issues, but in general you should choose the server location that matches the server you’re playing on (EU in your case) and choose the node to connect from the performance information under “Today’s Pathes”. There’s an autoselect option but personally I prefer choosing my node(s) manually. In my case, a low average RTT is important but if the RTT stddev is too high I will prefer a node with lower RTT stddev even if it has higher average RTT (my game is terrible in its handling of network instability). You might want to prune your list of nodes somewhat, e.g. you probably don’t need to have US nodes in your list if you’re connecting from China to Europe, so you can go to Setup > Nodes and blacklist the US nodes (and any others that are irrelevant to you, but the larger volume of irrelevant nodes is probably in the US), this should make configuration more manageable.
Thank you for help, i will try it right now and check out performance for each node with specific average RTT stddev and maybe i will try to blacklist nodes that i doesn’t really need like US
