how to change data plan
I’d refunded the game item and changed your data plan to PPT (Pay Per Traffic). Please check and let me know if it’s working properly.
Please check Final Fantasy XIV - A Realm Reborn though I’m not sure it’s helpful for you.
However is it How to check the basic functionality working fine?
Which protocol paladins use ?
MUDEC_00031 , MUDEC_00032 , MUDEC_00037 , MUDEC_00038
- Please try to turn off FastConnect mode or change your Connection
Protocol.
FastConnect
mode
will NOT useful in UDP. This feature is for TCP services.
Please confirm that How to check the basic functionality works fine with JP Asia (Hokkaido - SakuraNet) node in your environment. It’s a first thing you should test.
