how to set node? my location or server location to get the best ping?
and did i need full vpn or not?
i spend 1hour for setting but the ping also worst then no using mudfish…i have chose best node alreadu
or can u pls help me for my setting, fortnite asia server, i am from malaysia windows 10
and are u sure the server is at korea not japan?@@
i node kr 110ping node jp 70-90 ping
Ooops… You leaved too many questions and problems. I need to check it one by one. Please confirm that How to check the basic functionality works fine in your environment. It’s a first thing you should test.
but finally i get the problem is the destination should be japan~
as i say originally my ping was 80-99ms after i use mudfish just reduce 10ms… how can i get at least 50ms?
Please check my answer at other topic.
