How to stop mudfish from changing nodes
my node keep changing every time i connect, is there a way to make it stop from changing after i setup the nodes and path want?
I also Multi Path Mode if that means anything.
Thank you..
its written there it will change when using multi path so use basic or advanced and on basic and advanced if u have selected “auto selection” it will find and connect to the best one in every connect so it will change. To stop changing select server manually rather than using auto or multipath but auto is probably better.
