Hello.
I reported this problem earlier and got the reply to check http://docs.mudfish.net/en/docs/mudfish-troubleshooting/basic-func/
All of the below were using the Full VPN mode. I don’t have this problem using other nodes from US East. I completely disabled the Windows Firewall and don’t use another one.
The Program Core log is:
[STDOUT]
[0.009865] [INFO] mudfish v5.2.2 (for x86_64)
[0.010868] [INFO] Timestamp: Tue Apr 21 11:58:06 2020
[0.010868] [INFO] Full VPN mode is enabled
[0.010868] [INFO] Connection protocol: udp
[0.010868] [INFO] Authenticating…
[0.594533] [INFO] Fetching the static nodes…
[2.241194] [INFO] Fetched 462 static nodes from the master.
[2.255271] [INFO] TAP-Win32 Driver GUID {2882AA6B-6580-4273-8B79-DA27D74BD1A8}
[2.255271] [INFO] TAP-Win32 Driver Version 9.9
[2.255271] [INFO] TAP-Win32 Driver MTU 1500
[2.256280] [INFO] Setting TAP-Win32 Adapter v9’s MTU to 1400
Ok.
[2.319328] [INFO] TAP-Win32 Driver TcpNoDelay diabled
[2.319328] [INFO] TAP-Win32 Driver TcpAckFrequency 1
[2.319328] [INFO] TAP-Win32 Driver TCPNoDelay 1
[2.333341] [INFO] Uses the macaddr for msk(4) (cached).
[2.355361] [INFO] Fetching new static node SID 622…
[3.161249] [INFO] re419: Associating with ip 207.246.78.133 port 10008
[3.162249] [INFO] re419: Connected to 207.246.78.133:10008 (UDP)
[3.163364] [INFO] Setting the default gateway as 10.242.224.1 (622 (null))
[3.164368] [INFO] Ready
[3.238609] [INFO] Listening the management console at 127.0.0.1:59767
[4.170078] [INFO] Waiting until the client’s ready to handle the routing path list.
[4.822749] [INFO] DHCP request for 00:ff:28:82:aa:6b (DESKTOP-9F0F6J4) from interface
[4.829758] [INFO] DHCP discover for 00:ff:28:82:aa:6b (DESKTOP-9F0F6J4) from interface
[4.830758] [INFO] DNS address: 10.242.224.1
[4.833761] [INFO] DHCP request for 00:ff:28:82:aa:6b (DESKTOP-9F0F6J4) from interface
[4.834762] [INFO] DNS address: 10.242.224.1
[4.834762] [INFO] DHCP Client got IPv4 address now
[7.171046] [INFO] MFP 0 FlowMTU - 14.63.214.216 1500
[STDERR]
Empty file.
I can’t open https://myip.mudfish.net/ using the Full VPN in a browser mode but I can ping it as it shows:
Disparando myip.mudfish.net [172.105.228.51] com 32 bytes de dados:
Resposta de 172.105.228.51: bytes=32 tempo=242ms TTL=48
Resposta de 172.105.228.51: bytes=32 tempo=241ms TTL=48
Estatísticas do Ping para 172.105.228.51:
Pacotes: Enviados = 4, Recebidos = 4, Perdidos = 0 (0% de
perda),
Aproximar um número redondo de vezes em milissegundos:
Mínimo = 241ms, Máximo = 242ms, Média = 241ms
