I have a question about 5ewin
I have a question about 5ewin platform (A chinese cs:go matching client). Without mudfish, I got over 220ms ping from china mainland servers (except Hong Kong:I suspect Chinese great firewall affects the issue of ping). When I use mudfish, the ping looks like good like this picture and it is good in test server. But, I connect actually the matching servers, I got over 220ms and probably mudfish does not work. Can you tell me the solution of the issue ?
When I enabled Full VPN mode, it works perfectly. But If I could play 5ewin through mudfish without full-vpn mode, It is so good for me because I should turn off every connection except csgo and 5ewin.
And also, I sent you the packet dump when I play 5ewin (Hangzhou server) with full-vpn mode. I want to play 5ewin normal vpn mode.
It means that there’s a missed game server address block at the mudfish game item. :frowning: I’d checked your packet dump and updated the game item. Could you please test it again?
