I have installed mudfish to play TERA on EU servers but it doesn’t seem to lower my ping for some reason, I tried multiple servers and always go with the lowest RT avg yet my ping is still relatively high. Also, it is spiking (going from 100 to 400-500 for few seconds then going back to normal) which is causing me not to play the game properly.
Hello, I’ve tried using the settings as in the picture but now it’s not
working at all, maybe my ISP is blocking UDP protocol? what should I do?
(edit: in fact it doesn’t work now at all, except with TCP port 443)
I did everything, fast mode, full vpn mode, changed nodes and changed UDP ports, nothing works. it’s just that UDP Protocol does not work at all, it’s like im not connected to the internet when I choose it. and with TCP it’s laggy and not smooth at all. Is there a way to enable UDP protocol??
also I don’t know if that helps but I’m connecting from my university’s internet, so that might be the reason, I just really want it to work
I suspect there’s a Firewall
- Please try to use
-O
option to change the Mudfish’s working method as refer Firewall - Mudfish
Master
Server
Consider to change MAC Address
Consider reducing MTU from 1450
