I have tried using nodes from
I have tried using nodes from my own country and also the game’s country but the latency remains the same as before when not using this program.
Anything else I can do in the settings to solve this?
Did you try to change a mudfish node based on FAQ - Nodes section for your game item? If you’re using the advanced mode, please start with the basic mode. When I checked your RTT information, Hong Kong Azure mudfish nodes are good for your game.
The RTT average for Hong Kong Azure is indeed low and should be use-able. I tried using it now but my ping reduction is still negligible. It only reduces 10-20 ms,I tried turning off fast connect and it is still the same.
P.S I don’t think it reduces the ping, it stays around 270+ to 280+ ms
Are you meaning that with Full VPN mode (Hong Kong Azure) there was no ping changes at all?
Got it. But I need to check it first. Could you please test that it's also same with Full VPN mode enabled?
