I keep getting dc'd every 30 m
I keep getting dc’d every 30 min-ish whilst playing FFXIV:ARR and get error 90006 ingame with mudfish on. I’ve been using auto selection and then tried switching manually to a specific node but the result is the same. Without the VPN, my internet connection is fine and there are no stutters. Thanks in advance for any help!
Then did you try to use TCP protocol by chaning Connection Protocols?  Is it even same?
처리해 드린 것으로 보입니다. :slight_smile: 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
