i tried going full vpn for par
i tried going full vpn for paragon, im getting lag spikes, im playing from the philippines btw, playing at NA servers
Did you try to use Paragon item of Mudfish?  I’m not sure that you used Full VPN mode because it’s not working.
However to narrow down your issue, we should check first which this lag caused by.  Please try to change a mudfish node based on FAQ - Nodes link.  If it’s not helpful we need to do traceroute, WinMTR or PingPlotter tools.
