if I stream on twitch will it use my data? i want to use my internet data for streaming broadcast separate to my game using vpn.
no it wont… unless you use full vpn mode. otherwise it will only use your data when you playing the game
It depends.
Some items in Mudfish has conflict with services
on AWS like twitch so they would affected by your network access even
without Full VPN
mode.
Amazon EC2, Twitch and
Mudfish
As workaround, you can try to Create Custom
Item
as refer Unsupported
Games
Take a look and find the daemon process what you want to apply
Mudfish in Status → Memory
Then create a Custom Item as input the process name like
P:AProcessName.exe
