I’m failing to make it to work on the game “Grand Line Adventures”. It has multiple IP’s. Probably by the anti-DDOS and because the game change instances continuously.
IMG From Resource Monitor Windows7
Any hint?
Any hint?
You can try another way to Create Custom
Item
as refer Unsupported
Games
Take a look and find the daemon process what you want to apply
Mudfish in Status → Memory
Then create a Custom Item as input the process name like
P:AProcessName.exe
or
Packet Capture with
Mudfish
link while playing the game with Full VPN
mode.
We need some packets to update a Mudfish item.
