i’m having a problem using mudfish on discord
I turn on the mudfish and after a few seconds disconnect again. the voice chat on the discord blocked so each time I select another server a few second worked then happen again I still don’t know why
btw i’m using windows 7
Which discord server are you connecting? And could you please confirm that it’s also same with Full VPN mode enabled?
discord server is Center Europe , and yes I tried with Full vpn mode it doesn’t work and sorry for not answering you soon
처리해 드렸습니다. :-) 확인해보시고 문제가 있으시면 언제든지 답글 부탁드립니다.
