I'm having problem connecting
I’m having problem connecting to final fantasy xiv server in europe (germany)
Sorry for this belated response. :-(  Did you try to use Full VPN mode as temporary workaround?  Is it working fine on your environment?
I was using one nodes, and when the problem occur, the graph will show constant 3000 ms, but it really does not have connection
is your service not able to accept bitcoin temporary?
Cool!  please let me know again when this issue happens. :-)
:slight_smile: Thank you for sending the packet dump. Based on your packet dump, I had updated the game item. Could you please test with it? If it is not working properly, please let me know.
However when I checked this packet dump, I can see another game server at Germany. Is there multiple game server for MapleSaga?
Hi, do I equip MapleStory(Game Item) or continue using the Full VPN ?
Because I have a one month limitation that prevent me from going back to Subscriptions mode to use the one month game item. (I think the mode I’m using now will prevent me from using this game item as my other network traffic will still use my balance/bandwidth)
Yes, there are multiple connections from the game, the GM somehow can manage to reroute my network traffic from my end to another server at Netherlands to lower my latency.
Is it possible to change my account back to Subscriptions mode?
I changed it to Full VPN mode last time in order to do packet dump.
I have another 24 days to wait :\
Please use MapleStory and I think you can find MapleSaga destination for you now.
No problem. :slight_smile: I’d changed your data plan to Subscription and reset your changeable date too. If you’d like to change it back I think you can do again.
