I’m having problems with Bless JP. For some reason I can’t start the launcher throught web browser, I get to the game site but when the launcher is about to open I get an error. I already added the game to My Items and I’m using the Chrome addon with the same server(JP Asia (Tokyo - ConoHa 6)). For me it looks like the vpn isn’t working for the launcher, only for google chrome. I tested a different vpn to launch the game and closed it fast after the anti-cheat check and the game worked using Mudifish so it looks like its a problem detecting the game launcher.
I can only play if I use Full VPN with TCP. UDP isn’t working, I checked with my ISP and they say I have no blocked ports, it should work since i configured my router.
Then did you try to change MTU with UDP based? Please check MUDEC_00262 error link for details.
I did it now and didn’t work. Anything more I can try? I already disabled firewall on both my pc and router. I have no idea what could be.
However if it works fine with TCP protocol, I think you can keep the configuration because Bless game is also TCP based. However with TCP enabled and without Full VPN mode, is it your issue that you can’t connect to the game? If then it seems I need to some game packets to analyze.
The game only works with TCP enable using Full VPN mode. I would like to use the VPN only for the game. How can I help you with the game packets?
I sent you the packet by email
I tested and didn’t work with any of the TCP ports.
