I’m playing Blade and Souls on Garena which is in singapore. How should I set the vpn?
Please check Blade and Soul link though I’m not sure it’s helpful. However could you please check How do I know if its working? while playing the game? I need to check first whether the mudfish item works for your game server.
I tried to check of “How do I know if it’s working?” and it does disconnect the game when I force quit mudfish. Is there any way to check if the pings or anything that indicate that it’s does improve my game?
Okay so it looks it means that Mudfish is working fine for the game client.
I’m not sure How to check my ping document is what you’re looking for.
No, you won't :)
What about after release white/blacklisted Mudfish Node(s)?
