I’m using MAC. You replied but the fixes are for Windows. Please Help.
Connection protocol only shows udp and tcp but NO PORT numbers
Could you please elaborate your problem little bit more? I can’t follow your problem exactly. If you’re bad connection to the international connections, please try to change a mudfish node whose RTT stddev is quite low and stable. In my opinion, I think you should find where this bad congestion is from first.
