Hello! I had requested Infinity Nikki to be added to mudfish a while back and its been a godsend.
I have no idea what’s changed it was really set and forget I was even able to twitch stream but as of yesterday 7/01/25-8/01/25 the ping and lag are so bad its unplayable no matter what route or setting I use. I’m wondering if someone could help me troubleshoot?
Sounds like a technical issue? I know the game isnt being DDoS or people would be complaining on their discord & forums
there was even a hotfix and even then it didnt get better—it got worse.
If it works fine with Full VPN mode enabled, it means there’s something a problem in the game item of Mudfish. For that case, I need to collect some game packets using Packet Capture with Mudfish.
Hey there, while yes there were ping issues for 2-3 days I discovered it was actually on my end. I reformatted and using mudfish everything is working now. Thanks!
