Is it my own problem that I ca
Is it my own problem that I cannot play BnS TW at all! No line can be used with high package loss at the first jump.(I tested that with tools). that means I have problem connecting to master servers. This thing takes me 30 minutes everyday to find a suitable line, kind of wasting my time!
If you’re familiar with WinMTR or PingPlotter, please try to test your internet first. For details, please check How to use WinMTR section. At this moment I don’t know where this issue is from so no more helpful comments I can give you.
Sorry sir. Hope you can see the pic I uploaded here. As you can see, no matter which line I choose, I get something like the screen shot shows: to much dropped packages, from the very beginning. BTW, this is tool that you mentioned – PingPlotter. Hope this helps.
Please try to test again to the public IP of mudfish nodes. It seems this result shows that there’s a packet loss between your ISP and mudfish nodes.
If I switch to TCP, then the package loss will gone, but instead, there is really very high ping. Think maybe it is because of the f*ucking Chinese GFW. Do you have any methods to pass through it?
You’re already well sets it up as through Hong Kong and Taiwan. It’s general way to connect with China. As you know we have barely methods to connect to China as poor nodes so if you doubt the Great Firewall I think there’s no many options for reduce your RTT
Ok. makes cense. Last question: is there any difference between normal mode and full VPN? I mean for gaming?
There’s no differences, fundamentally. But some items has insufficient routing paths so sometimes cannot connect to the endpoint. The Full VPN mode guarantees reach to a destination node what Mudfish have at least except out-of-traffic status or environmental disaster
