Is it possible to automaticall
Is it possible to automatically start Mudfish with Windows and without it having to open Google Chrome every time it launches? The Network 1, Network 2 etc. is kinda annoying too.
There’is… You can use ‘Task Scheduler’ but not well documented yet. :frowning: The korean version exists at 프로그램 관련 (윈도우) — Mudfish 4.3.8 documentation but not easy to follow. Please let me allow update these.
Please check Merge network profiles for details about how to stop it.
I’m really sorry for the delay. For some reason I missed this topic along with my saved links. But thanks for the explanation!
Have you had the chance since I posted this to update the ‘Task Scheduler’ wiki page? I would appreciate it a lot!
So Windows 10 really doesn’t provide an option to disable the creation of new network profiles? :frowning:
Thanks!
I have figured how to use the Task Scheduler, it seems to be working great. Thanks! The only really annoying thing is this Network Profile thing that pops up every time I start Windows. Isn’t really a workaround to make it go away on Windows 10? Or maybe something you could change on Mudfish to bypass it?
Thanks again!
For this issue, please check Merge network profiles section. :slight_smile:
