Is it possible to designate Mudfish to start function only on the apps I want it to function?
Which mudfish program are you using? Are you using for mudfish apps for smartphone?
mudfish website on PC I wanted it to run on just a specific program.
I’m not sure which specific program you’re trying. However please check Create Custom Item if you know the IP addresses the program’s connecting.
