Is it possible to run mudfish
Is it possible to run mudfish with node.js (using for a proxy) so I can get the auto routing from mudfish?
Which mudfish service are you trying to use? If you’re using Mudfish HTTP / SOCKS Proxy I think you can make a program based on node.js
