Is there a way to use CN node?
i have try use different protocols
it changed nothing
Constantly get “Request timed out”
At http://en.loxch.com/servers.php link, you can find all public IP of China nodes.  Could you please send a ping to each public IP?  Is it all failing?
Test all connection protocol
Result is same
With following result
ping CN nodes internal IP - all ok
ping CN nodes public IP- all ok
ping public IP for any other VPN nodes  - all ok(ping for it stay same as without vpn so it seems signal go same route as without vpn)
ping any other IP in the internet - Request timeout
Example
http://imgur.com/KIeEcNE
Vpn node - CN Asia (Beijing - Aliyun)
Public 101.201.105.26
Internal 10.245.128.1
Test node for ping
ping without vpn 62 ms ping with vpn 62 ms
DE Europe (Germany - DigitalOcean)
Public 46.101.228.155
Internal 10.250.192.1
Internet IP 123.125.114.144 (baidu.com)
Thank you for reporting this issue!!!  Without your help, I can’t figure out this problem at all.  Really appreciate it. :-)
등록되지 않은 게임이라면 게임 가속 요청 문서를 참조하셔서 게임 패킷을 보내주세요. :slight_smile: 제가 분석 후 등록해 드릴 수 있습니다.
일본 리그 오브 레전드는 지역 제한된 게임이기 때문에 리그 오브 레전드 (일본)을 참고해서 접속하시기 바랍니다.
그 외, 크레딧 소모와 관련된 정보입니다.
CDN과 미꾸라지
