I dont know why but since a few days / weeks the nodes, that are connecting me from JP (hokkaido) to oregon, to play lost ark in NA west, have gone from 116ms ping to 126ms+ and are very unstable, with lots of packet loss / ping spikes in the evening (JP time 4pm to 10 pm+)
Maybe you could look into that, as it seems that there is a problem. Thanks.
same issue here, every nodes are very unstable.
refreshing for new paths only work for like an hour then latency started to spikes again,over and over.
Did you try to change a mudfish node based on FAQ - Nodes section for your game item?
