it wont load
- I think give it a try to pick only 1 Mudfish Node will show more accurate results
- You can inspect how network traffic goes on with tools like WinMTR or PingPlotter.
I understand, and will look into this.
However, before 4.6.0 it showed very accurate values.
So per example, when I load, this is what it looks like at the moment:
However, if I load the top one, the Dashboard does this:
I mean, I just randomly try around until I find a combination that works, but just wanted to report it because I don't think that's how it is supposed to go :P
Kind regards,
Sat
PS: This also defeats Auto Configuration, too.
What about Full VPN mode?
