It’s kind of hard to connect through Black Desert Online.
Please check How to check the basic functionality first and make sure that at least it works fine.
Is your problem happening even with Full VPN mode? And did you try to use TCP protocol after changing Connection Protocols?
Here it is - http://crs.loxch.com/report/files/20170327021348_packet_dump.pcap
Cheers!
이 부분은 특별히 문제가 있는 부분은 아닙니다. 다만 해당 부분이 거슬린다면 네트워크 위치 병합 섹션을 참고하시면 될 것 입니다.
아~ 바쁘실건데 감사합니다~~ ^^
