Ping is high when using for mobile legends PH Server. Pls help.
Do you use mudfish app for iOS or Android? Or use mudfish for desktop? And did you try to change a mudfish node based on FAQ - Nodes section?
Thank you for this screenshot. However when I checked this, it seems you’re using UDP Port 53. Is there any reason to use this port as Connection Protocol?
If possible, please try to use UDP Port 10008 (default) and decrease the MTU from 1450 to 1400 or 1300.
