Lag issue
When I’m playing maplestory sometimes when I watch youtube or netflix my maplestory lags, but I’m using WFP and have Web Inspect feature on. Is there anyway to fix this ? and is this possibly why my consumptions seems high? when I use youtube/ netflix?
Weird… While you feel lags, did you check “Realtime Traffic Graph” on the mudfish dashboard?
I’m curious how it looks like when the issue is happening. If the graph shows abnormal high traffics, it means something is wrong..
is this normal?
Yes.. Definitely it looks very normal. No high traffics observed so it means YouTube or Netflic traffics doesn’t go through Mudfish. Only the game traffics are here.
However if the lag happes, it might be more related to other facts (e.g. CPU, Memory and etc..). Did you try to monitor the task manager while the issue was happening?
