LoL Nodes for Korea Banned
Hello, some of the fast KR Nodes are banned. Whenever, I use them, I am unable to log in to Riot Client. Therefore, I am forced to use the other, higher ping nodes. I want to use the lowest ping nodes but they are banned. Can you add 1 or 2 more nodes that are similar to Azure? Because they are the fastest one for me.
Thanks.
No problem. I’ll try to add more KR Azure nodes when I get a chance, As workaround, did you try to use “Advanced Mode”? For example you can make a chain “You -> KR Azure node -> KR game accessible node -> game server”.
Yea I did try to use “Advanced Mode”. However, I tend to get 500+ ping, and its more unstable.
