Lost Ark JP not accessible
Hi as mentioned on title
I want to go to https://lostark.pmang.jp/ to download the Lost Ark Client and play.
I noticed majority of the JP nodes could not access the site, let alone download the client.
Please let me know if all the nodes have been blacklisted by Pmang Japan.
Also, I noticed Abema TV videos also has the same issue
I had the same issue when using basic mode. When randomly trying out advanced mode it worked for me.
IIRC Pmang Japan has very strict policy to block VPN connections. So I think most of mudfish nodes are already blacklisted. :frowning:
it working with full vpn but not working without full vpn enabled
Good to hear that it works. However which mudfish node did you use for Full VPN mode? Not sure that you tried with mudfish nodes or others…
Anviu, could you please let us know how to make it work in advance mode? It means you are not using full VPN mode right? Which nodes did you use?
Thanks in advance
So I got it to work. I opened pmang page on another tab of the same window as my mudfish control panel. bcs it runs as admin (I run on standard account on win10). When starting mudfish, win10 UAC kicks in and it runs as admin. Hth someone out there.
