macOS Monterey 12.0.1 - Core process not running
  1. What’s your issue encountering?
    Unable to connect to full VPN with any nodes on macOS Monterey 12.0.1
  2. How could it be reproducible?
    Able to launch mudfish vpn (allowed connection in security & privacy), VPN connection is shown in network connections but does not connect. Getting stuck at core process not running on dashboard.
I’d leaved my answer at other topic you created at Private Support menu. Please check it there. :slight_smile: You can find your topics at https://mudfish.net/forums/iwrote link.
At this point, macOS Monterey doesn’t be fully tested. When I get a chance, I’ll try to upgrade my MacBook from Big Sur to Monterey and test it.
I got it figured out. Uninstalled arm64 version and downloaded the x86_64 version, and it all works now! Thanks for the response. :+1:
