Man it happened again. I didn’t play any games but forgot to turn of mudfish. It wasn’t even on item (not full vpn) but ate 40 gbs of traffic… You should fix this.
Frankly speaking, it’s not easy to fix this issue at Mudfish side because our implementation is based on the routing table of OS.
So you should check CDN and Mudfish section and see the workarounds.
