I’m unable to get past the title screen on Fate/Grand Order on Bluestacks when Mudfish is active. If I’m already past the title screen though, Mudfish doesn’t mess with the game at all. I’m forced to disconnect Mudfish, get past the title screen then reconnect again, which forces me to restart MapleStory. Any solutions?
Please confirm that How to check the basic functionality works fine in your environment. It’s the first thing you should test.
Mudfish is working properly for my game (MapleStory). It’s just messing with other apps on my PC (download speed on browser, Steam, connection in other games).
Got it. Then please check CDN and Mudfish document for your issue. MapleStory game item has this issue… So I think that’s a reason why you encounter it.
If possible, you can try to test with Full VPN mode + WFP Item mode combination whether it helps your problem.
