I’m in Asia and try to play GMS. But mudfish automatically route me to JP (which MapleStory has a server there), meaning they will block you try to play GMS with Japan IP.
Any node recommendation? How can I find out which node fit me?
you can’t play GMS with JP node
use US node or advanced node mode with JP → US setting
