The FR Marseille node just disappeared, when I tried using it it said “dead node” is being used and then when I went to go select another node it was no longer available on the dropdown. It gives me the lowest ping in Overwatch because I have a direct link to the cable so I’d appreciate some help.
@arissi Could you please check it again? When I checked the mudfish node status, it shows it’s running right now.
It came back the next day after I woke up
