Max speed is lower than plan, and problem with cash shop in maplestory
Hi, I’m using mudfish to play global maplestory, and recently entering the cash shop requires receiving alot of packets. I noticed that the speed limit was making this process very slow when loading, so I bought the 8-2 plan thinking it would speed it up. But from task manager and the real time traffic tx bits, mudfish still caps at 1mbps receive instead of 2 which i paid for. Also wondering if the maplestory item could be improved as loading into the cash shop takes 40seconds++ instead of normally around 8 seconds with the recent change to how the cash shop is being loaded.
If you’re using higher voucher for Subscription data plan, please make sure that you’re using the latest mudfish version 5.4.6 because it’s required to work properly.
