I suddenly have a -$0.6 credit from around 25GB of data. All I have activated was discord, Apex, and a Project Zomboid item. I wasn’t in full VPN either.
What gives?
What gives?
First sorry for this inconvenience. Unfortunately, I think your issue is related to Amazon EC2, Twitch and Mudfish and CDN and Mudfish links. Please read these documents.
However, I’d reset your mudfish credits a little bit.
Hello. I also just encountered this issue yesterday while playing Final Fantasy 14. I was not watching Twitch at the time it happened, I simply disconnected from wifi and reconnected, then noticed I was massively lagging for about 10 minutes and then credits were gone. I had about 22gb of data left at the time and it was reduced to only 3gb. Logs can be checked to confirm this I believe. I bought more credits after but I would love any tips to avoid this issue in the future, I was not using full VPN mode, but was using multi-node with fastconnect as normal.
Update: Here’s my traffic chart:
Please visit ‘Account → Edit profile’ menu to enable the Connection Log feature to see where your traffics were used. You can find it at https://mudfish.net/admin/user/modify link.
For your convenience, I’d reset your mudfish credits a little bit.
