[MUDEC_00003](https://mudfish.
MUDEC_00003 problem here no tap . have tried the suggested solutions. nothing worked. please help
Please confirm that if pass How to check the basic
functionality
then check where the program is in C:\Program Files (x86)\Mudfish Cloud VPN\ or not and are mudfish.exe / mudflow.exe into the path then
execute Mudfish VPN Launcher at Start Menu than any shortcut what you’ve
created.
  • Please download a driver in 32-bit or 64-bit for your system
static.loxch.com/tools/tap0901-i386.zip
(32 bit)
static.loxch.com/tools/tap0901-x86_64.zip
(64 bit)
  • Extract it then run remove.bat
  • Run install.bat
I’m not sure if following information are related but I leave them
MUDEC_00044
MUDEC_00045
MUDEC_00086
