Mudfish Forums
mudec-00280how to fix
Technical Support
2896970400
July 6, 2019, 4:00pm
1
mudec-00280
how to fix
kwangseok
July 8, 2019, 2:31am
2
MUDEC_00062
Please try to turn FastConnect mode off or change your
Connection Protocol
MUDEC_00280
MUDEC_00334
change your
node
https://mudfish.net/forums/6/topics/44662
Connection Protocol
in TCPs
https://mudfish.net/forums/6/topics/37597
consider to change
MAC Address
consider reducing
MTU
from 1450
run Mudfish with option lowercase `-s`
then access to
https://ui.mudfish.net:8282
connect with
Mudfish DNS Client
If Mudfish DNS Client doesn't work,
gpedit.msc - Local Computer Policy - Computer Configuration - Administrative Template - Network - DNS Client - Turn off smart multi-homed name resolution - Enabled - OK
Control Panel\Network and Internet\Network Connections - TAP-Win32 Adapter V9 - Internet Protocol Version 4(TCP/IPv4) Properties - General - Advanced... - IP Settings - Automatic metric - Interface metric - recommended 15
use capital `-O` option to change the Mudfish's working method as refer Firewall -
Mudfish Master Server
China
