I’m using mudfish on MacOs and these two errors pop-up [2.781237] MUDEC_00327: Failed to connect(AF_SYS_CONTROL) to utun. and [2.781301] [CRIT] Assert (fd >= 0) failed at ODR_open_tuntapdev (./mud/os/macosx/syscalls.c:741) with 0
Ooops..
Which Mac OS X version are you using? And are you running another VPN program on mac too? This error means that it failed to create utun(4) interface. But it seems it doesn’t show details. Please check ‘Status → Process’ menu to see “Core” log section. It’ll include some details about why.
I’m using Mac OS Catalina version 10.15.6 and im not using another vpn program, just mcafee virus protection. I’m not really good with computer things, should I just send what it says to you?
Please check ‘Status → Process’ menu to see “Core” log section and show me the full logs of core part.
I think it’ll include some more detailed error codes to analyze your issue. Sorry for this inconvenience.
I think it has fixed itself cause there is a tick next to the “core” but when I go to check on myip.mudfish.net, it says im not connected to mudfish… here’s the log of the core part
[STDOUT]
[0.005173] [INFO] mudfish v5.2.4 (for amd64)
[0.005877] [INFO] Timestamp: Mon Sep 28 18:03:43 2020
[0.005973] [INFO] Connection protocol: udp
[0.006054] [INFO] Authenticating...
[0.696814] [INFO] Fetching the static nodes...
[2.601977] [INFO] Fetched 453 static nodes from the master.
[2.602355] [INFO] connect(AF_SYS_CONTROL) failed: 16 Resource busy
[2.616295] [INFO] No load calculation for clock.
[2.622096] [INFO] Child said: Executing /sbin/ifconfig utun2 10.254.203.74 10.254.203.1 netmask 255.192.0.0
[2.627297] [INFO] Child said: R 1453 Status: 0000
[7.625844] [INFO] Ready
[7.627003] [INFO] Child said: Executing /sbin/route add 10.192.0.0 10.254.203.1 -netmask 255.192.0.0
[7.636783] [INFO] Child said: add net 10.192.0.0: gateway 10.254.203.1
[7.636968] [INFO] Child said: R 1454 Status: 0000
[7.637924] [INFO] Child said: Executing /sbin/ifconfig utun2 mtu 1392
[7.644151] [INFO] Child said: R 1455 Status: 0000
[7.702122] [INFO] Listening the management console at 127.0.0.1:51779
[8.630056] [INFO] MFP 0 RouteAdd - 103.23.4.0 255.255.252.0 1 37987 0 n
[8.630166] [INFO] Fetching new static node SID 1...
[9.698885] [INFO] re0: Ethernet address: 56:50:0a:5d:fa:96
[9.699117] [INFO] re0: Associating with ip 180.149.230.54 port 10008
[9.699494] [INFO] re0: Connected to 180.149.230.54:10008 (UDP)
[9.700204] [INFO] MFP 0 RouteAdd - 202.166.185.0 255.255.255.0 1 37987 0 n
[9.700469] [INFO] MFP 0 RouteAdd - 203.104.224.0 255.255.224.0 1 37987 0 n
[9.700885] [INFO] MFP 0 RouteAdd - 23.192.0.0 255.224.0.0 1 37987 0 n
[9.701031] [INFO] MFP 0 RouteAdd - 23.32.0.0 255.224.0.0 1 37987 0 n
[9.701206] [INFO] MFP 0 RouteAdd - 23.64.0.0 255.252.0.0 1 37987 0 n
[9.702271] [INFO] Child said: Executing /sbin/route add -net 103.23.4.0 10.254.203.1 255.255.252.0
[9.703368] [INFO] MFP 0 RouteAdd - 176.255.202.0 255.255.255.0 1 37987 0 n
[9.703512] [INFO] MFP 0 RouteAdd - 203.104.248.0 255.255.255.0 1 37987 0 n
[9.710296] [INFO] Child said: add net 103.23.4.0: gateway 10.254.203.1
[9.710505] [INFO] Child said: R 1456 Status: 0000
[9.711423] [INFO] Child said: Executing /sbin/route add -net 202.166.185.0 10.254.203.1 255.255.255.0
[9.717221] [INFO] Child said: add net 202.166.185.0: gateway 10.254.203.1
[9.717436] [INFO] Child said: R 1457 Status: 0000
[9.718370] [INFO] Child said: Executing /sbin/route add -net 203.104.224.0 10.254.203.1 255.255.224.0
[9.722792] [INFO] Child said: add net 203.104.224.0: gateway 10.254.203.1
[9.723022] [INFO] Child said: R 1458 Status: 0000
[9.723687] [INFO] Child said: Executing /sbin/route add -net 23.192.0.0 10.254.203.1 255.224.0.0
[9.727786] [INFO] Child said: add net 23.192.0.0: gateway 10.254.203.1
[9.727913] [INFO] Child said: R 1459 Status: 0000
[9.728459] [INFO] Child said: Executing /sbin/route add -net 23.32.0.0 10.254.203.1 255.224.0.0
[9.732094] [INFO] Child said: add net 23.32.0.0: gateway 10.254.203.1
[9.732296] [INFO] Child said: R 1460 Status: 0000
[9.732897] [INFO] Child said: Executing /sbin/route add -net 23.64.0.0 10.254.203.1 255.252.0.0
[9.736932] [INFO] Child said: add net 23.64.0.0: gateway 10.254.203.1
[9.737056] [INFO] Child said: R 1461 Status: 0000
[9.737657] [INFO] Child said: Executing /sbin/route add -net 176.255.202.0 10.254.203.1 255.255.255.0
[9.741454] [INFO] Child said: add net 176.255.202.0: gateway 10.254.203.1
[9.741565] [INFO] Child said: R 1462 Status: 0000
[9.742058] [INFO] Child said: Executing /sbin/route add -net 203.104.248.0 10.254.203.1 255.255.255.0
[9.745364] [INFO] Child said: add net 203.104.248.0: gateway 10.254.203.1
[9.745465] [INFO] Child said: R 1463 Status: 0000
[STDERR]
Empty file.
Okay.
When I checked this problem report, it seems your crash issue is now solved.
Did you equip “What’s my IP?” item? If you’re not using Full VPN mode, it’s required to equip before visiting https://myip.mudfish.net
