hi after the installation of the new mudfish i have this MUDEC_00357 error where it says that my account isn’t activated whenever i try to connect.
MUDEC_00357 error means that your connection is blocked due to too many login failures. Which version of mudfish are you using? Is it v5.0.6?
how do i check? i just click on the update when i get offered to when i open my mudfish launcher. i think it should be the newest one?
Did you try to use mudfish v4.6.1 which found at https://mudfish.net/releases/ link? If this issue happens with v5, I think you can try to test with v4.
