MUDEC_01159 Unable to calculate RTT with destination using ICMP protocol
HI
there sees to be a problem with Apex Legends Game Server Location * Destination: eu-central-1, Europe (Frankfurt) in mudfish only and only this server other servers are working but this one is what i need, I kindly request you support to fix this ASAP.
thanks
Mohammed
Weird… Is this issue still the same? When I checked the mudfish side, it looks good to me.
If it’s still the same, it might be something is blocking ICMP echo request.
its fixed after the latest update
Hi,
the issue is back again, i think this problem is happening every now and then not always, because sense I reported it after 2 days its fixed then again yesterday its back and still not working as it should, please help
I’m sorry to hear the issue has returned. That is quite strange!
Could you please send me a Problem Report while this issue is happening? I need to check the internal logs to see exactly what is going wrong on the backend during these moments.
Once I receive it, I’ll take a closer look right away. Thanks for your patience!
