My mudfish browser extension times out after failing to load for a long time. It used to work previously when I connect to JP Asia (Tokyo - Google 4). I tried different nodes and am still experiencing the same issue. I also tried uninstalling and reinstalling the extension. Lastly, I also checked to make sure I still have a credit balance to make sure that was not the issue.
Weird… Is it still same? I can’t reproduce this issue on my side. It looks it’s fine at this moment. Sorry for this inconvenience.
Yes, it’s still the same.
These are the nodes I used to be able to connect to for Granblue Fantasy through the browser extension. Now it just stays stuck on loading and fails to connect.
I also checked using the MudFish Launcher by enabling Full VPN Mode for the node, connecting, and it says it works https://i.imgur.com/SXg7OT6.png. I am not sure why it seems to be working through the Mudfish Launcher only now and not the browser extension.
Did you try to test as follows?
- Pick ‘JP Asia (Tokyo - Google)’ and sign in with your mudfish ID / PWD.
- Then visit http://myip.mudfish.net/ link.
Are you meaning that if you follow above steps, the browser stuck and be failing to connect?
Yes, that is correct. I picked “JP Asia (Tokyo - Google)” through the browser extension. I made sure I was logged in with my Mudfish ID/PWD. The browser is then just stuck and fails to connect.
It looks this topic is duplicate with one at “Private Support”. I’ll leave my answer at there.
