Mudfish disconnects my interne
Mudfish disconnects my internet for some reason. This is the first time I’ve encountered this problem. For some reason when I use mudfish my internet doesn’t work fine, when i go to websites such as facebook or youtube it says the dns has no response or there is no internet connection. I’m 100% sure that the FULL VPN Mode is turned off and all the games are turned off on the vpn as well. Even when I quit mudfish my internet still doesn’t work unless I restart the pc, refresh the internet through gateway or completely uninstall the program. Please help.
The packet loss on most servers are 50-100% too, there are some that fine though but mostly are 1k-3k.
In mudfish, 3000 ms ping means there’s a packet loss between mudfish node and your desktop.
It is working. However I don’t want to fully turn on the vpn and only for some games to save data and when I do that I can’t browse the internet, my connection is suddenly cut off.
I see and understand your concern. However are you meaning that with Full VPN mode enabled your issue is gone? If then, it’s weird for me.
