Hy, I recently bought a Netgear Nighthawk xr300 hoping for better ping and less lag in ePes2021, but when I use Mudfish can’t get the connection between me and opponents. This only happened after I bought the Netgear router. I also tried to chance protocol mode from settings in Mudfish but still doesn’t work. Any suggestions are appreciated. Thanks
I don’t think you’re using the mudfish program for routers, right? I guess you’re using the mudfish for PC and desktop.
