Chrome extension no longer works, phone is sporadic?
GWF blocks mudfish.net domains at this moment. I think you should fix DNS poisoning issue from GWF. Did you try to consider to use Mudfish DNS Client?
Hey, thanks for the reply. Currently using another VPN to access the website, but I will try if DNS works. Will there be a fix for the DNS poisoning from GFW? And does this DNS download have an Android version?
