Mudfish for maplestory question on some configuration
Hi I would like to know if there is an option or setting to enable vpn only apply for that particular application/games that I select ? So that I can still stream youtube using my own network or other stuff like login to steam using my own network…
thanks!
@muddyray Did you check Create Custom Item document before? It seems it’s what you’re looking for.
And please check MapleStory link too because it explains how to set up Mudfish for MapleStore game.
